philfrost432 Posted May 9, 2014 Share Posted May 9, 2014 I can not manage too get the end of the shafts out I have pulled it out of the rubber gaiter but just carn't get the ends out I was told the gearbox is a oem LSD but, could be something else but it is 100% LSD, I am not sure if this makes any difference but the part of the driveshaft that is still in the gearbox is green both sides any one know what gearbox it is?or how too get these bits of the shaft out I have tried too knock them out just don't want too move need them out too fit new gaiters 😒 I would post a photo but my iPad will not let me Any help would be apriciated thanks Quote Link to post Share on other sites
5e colin Posted May 9, 2014 Share Posted May 9, 2014 like i said before on the cups is a rim put a bar in there and hit the bar with a hammer it will pop out mayby yiu need a stronger arm :) but you can leave them i n the box if you want just undo the clip around the inner gaitor and the shaft will slide out the 3 balls is held in place by a clip remove that then the balls now work your way to the out side of the shaft do the same there you dont even nead to take the drive out tha hub !!!!!!!!! Quote Link to post Share on other sites
philfrost432 Posted May 9, 2014 Author Share Posted May 9, 2014 Okay mate thanks for the help will just leave the in the box and do it that way as don't want too damage them trying too knock them out I can fit the gaiters on the shaft then slide them on as you say mate cheers for the help Quote Link to post Share on other sites
5e colin Posted May 9, 2014 Share Posted May 9, 2014 yes you only nead to remove the 3 bots for the balljoint ( and wheel ) that way you can slide it out of the cup on the gearbox side put cardbourd on the floor dont wanna damage the 3 bals !! Quote Link to post Share on other sites
