Kai_ethan Posted May 11, 2014 Posted May 11, 2014 What's the best way to install a oil temperature gauge, like where to put the sensor thanks Quote
maddox710 Posted May 11, 2014 Posted May 11, 2014 Buy a oil pressure sandwich plate and screw the sender unit into that the run the wires to gauge etc Quote
Cushion Posted May 11, 2014 Posted May 11, 2014 Yeah but you'll need to grind some of the p/s bracket away, if you got p/s Quote
