brendonware Posted May 12, 2014 Posted May 12, 2014 Where can i buy extended studs? are they easy to change? Thanks, Brendon
richardc9052 Posted May 12, 2014 Posted May 12, 2014 Piss easy to change. See if you can find a mk2 mr2 about for breaking. They are much longer and you'll have 4 spare then ;)
brendonware Posted May 13, 2014 Author Posted May 13, 2014 http://www.ebay.co.uk/itm/TOYOTA-MR2-EXTENDED-WHEEL-SPLINE-HUB-STUDS-M12X1-5-62MM-/300974690706?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item46137d5192 ? Brendon
WallaceGlanza Posted May 13, 2014 Posted May 13, 2014 Easy to get the old ones out but pulling the new ones through isn't easy unless you have a nice impact gun to help.
brendonware Posted May 13, 2014 Author Posted May 13, 2014 I think i should be able to borrow my bosses impact gun cant seem to find them anywhere though Brendon
Fozzie Posted May 13, 2014 Posted May 13, 2014 What about these? Basically the same as the MR2 ones by the look of it but listed for the Starlet/ http://www.fensport.co.uk/Parts/Model_40/Category_2/3469
richardc9052 Posted May 13, 2014 Posted May 13, 2014 I'm not sure on lengths but check the standard size. I'm sure it's 40-50mm so 65 should be plenty good price per stud too.
