Amjad Posted May 15, 2014 Posted May 15, 2014 (edited) What are your suspension mods, tyres, and what damping rates do you like to run? E.g. My GT has Meisters, ZEP Racing panhard rod, Whiteline 24mm FARB, Whiteline fixed RARB, Polybushed rear beam with adjustable camber, LSD, braces, Rainsport 3's. F12 R8 Would be interesting to see of what people that have experimented rate as a good setup! Amjad Edited May 20, 2014 by Amjad Quote
morgey Posted May 15, 2014 Posted May 15, 2014 (edited) Currently experimenting and not happy with it on B roads as im getting loads of bump steer that I need to look at but that's only came about since having my suspension off for a clean and serviceBC coilovers standard springs 6/4 iircWhiteline 24mm farbFixed RarbAlkAd08'sJust had tracking done.Toe is 0Camber 0.45Front 6 Rear 4Tyre pressures are 23/20 front rear. Track usage I was told to turn the damping to 18-20 front and 14-16 rear. And to turn it harder until the understeer minimises. Seems a strange setup but was recommended by a lotus technician. I can understand the thinking behind it but yet to test it on track!Might set it to have some toe in and see how it goes. I'd like to think that will help the bump steer? Edited May 16, 2014 by morgey Quote
Amjad Posted May 15, 2014 Author Posted May 15, 2014 I've got - 1.3 camber, 0 toe and rear camber around -2Not too sure about bump steer, never really thought whether I get any. But I find at the front set to around 15 or so, I have nice direct steering feel but the car tends to bounce along bad roads. And at too soft a setting it feels too wooly. On the rear I'm trying to figure out what would be best for lift off oversteer to make the back rotate on demand. Currently it just grips (probably due to the rear camber lol) Quote
Mad Mike EP82 Posted May 16, 2014 Posted May 16, 2014 Currently experimenting and not happy with it on B roads as im getting loads of bump steer that I need to look at but that's only came about since having my suspension off for a clean and serviceBC coiloversWhiteline 24mm farbFixed RarbAlkAd08'sJust had tracking done.Toe is 0Camber 0.45Front 6 Rear 4Tyre pressures are 23/20 front rear. Track usage I was told to turn the damping to 18-20 front and 14-16 rear. And to turn it harder until the understeer minimises. Seems a strange setup but was recommended by a lotus technician. I can understand the thinking behind it but yet to test it on track!Might set it to have some toe in and see how it goes. I'd like to think that will help the bump steer? I run standard farb and adjustable rear set to max geometry is top secret ;) 8kg front spring 6kg rear tyre pressure 26-30 front 28-32 rear. Quote
morgey Posted May 16, 2014 Posted May 16, 2014 I liked mine with the oem farb.This was coming round some quite bumpy corners the steering was snatching and pulling me inwards quite a lot which was causing the car to get a bit unsettled. Didn't fill me with the most confidence so I slowed up rather than binning it! Quote
Mad Mike EP82 Posted May 16, 2014 Posted May 16, 2014 I liked mine with the oem farb.This was coming round some quite bumpy corners the steering was snatching and pulling me inwards quite a lot which was causing the car to get a bit unsettled. Didn't fill me with the most confidence so I slowed up rather than binning it!Coilovers for starlet turbo are not good for B roads you want bilstein dampers with good quality springs. Car will be higher in ride height tho but will take bumps an dips in the road much better Quote
morgey Posted May 16, 2014 Posted May 16, 2014 Naa I've driven it down roads like this before and it wasn't anything like this. I'm going to have a look over it and see if there's anything obvious loose or maybe replace my ball joints as that's the closest thing I've had gone that felt like this. Quote
AdamB Posted May 16, 2014 Posted May 16, 2014 As low as possible to the ground, with the softest springs you can get away with without the car bottoming out. Bump and rebound settings depend on the surface your driving on really. Something with the weight of a starlet a spring rate of something like F 6kg/mm R 4kg/mm. With a stiff rear anti roll bar. Quote
GP82 Posted May 16, 2014 Posted May 16, 2014 (edited) Amjad you need more neg camber at the front! More then the rear! The dampening setup will be trial and error testing to see how the car will react with the rest of your chassis setup, more importantly in relation to your spring rates. Generally you have a more dampening rate (compress and rebound) at the front on FWD then the rear, but you can increase this abit to make it more aggressive if you have a more grippier tyre. The car will also change direction faster now, so you will have to carefully dial in the rear of the chassis so to keep it stable, for more compliance in the rear. As mentioned tyre pressure's play a big role! This is all for driving on a track, for the road i agree with what has said above that a good shock and spring combo is best. Edited May 16, 2014 by GP82 Quote
Amjad Posted May 20, 2014 Author Posted May 20, 2014 I run standard farb and adjustable rear set to max geometry is top secret ;) 8kg front spring 6kg rear tyre pressure 26-30 front 28-32 rear.Mike what other handling mods do you have/recommend? I liked mine with the oem farb.This was coming round some quite bumpy corners the steering was snatching and pulling me inwards quite a lot which was causing the car to get a bit unsettled.Didn't fill me with the most confidence so I slowed up rather than binning it!I might try mine with OEM FARB before JF2 and see how it feels As low as possible to the ground, with the softest springs you can get away with without the car bottoming out. Bump and rebound settings depend on the surface your driving on really. Something with the weight of a starlet a spring rate of something like F 6kg/mm R 4kg/mm. With a stiff rear anti roll bar.Stock Meisters are F 5kg/mm R 4kg/mm. I was thinking of getting stiffer fronts but might leave it until next year. I do want my RARB stiffer though! Amjad you need more neg camber at the front! More then the rear! The dampening setup will be trial and error testing to see how the car will react with the rest of your chassis setup, more importantly in relation to your spring rates. Generally you have a more dampening rate (compress and rebound) at the front on FWD then the rear, but you can increase this abit to make it more aggressive if you have a more grippier tyre. The car will also change direction faster now, so you will have to carefully dial in the rear of the chassis so to keep it stable, for more compliance in the rear. As mentioned tyre pressure's play a big role! This is all for driving on a track, for the road i agree with what has said above that a good shock and spring combo is best.Yeah think I may go for -1.5 front camber (so a touch more) and maybe look to reducing the rear to be more equal to the front. That's what I've found, the car is a lot pointier with front suspension set harder. I've tried softer at the front and it doesn't feel right for me. If anyone would want to swap an adjustable Whiteline RARB for my non-adjustable pne I would like to, as I'd prefer it to be set to hard all the time. Would pay too of course.. Quote
Mad Mike EP82 Posted May 20, 2014 Posted May 20, 2014 Mike what other handling mods do you have/recommend? Depends what your using your car for as said my setup is NOT good for bumpy b roads more track suited (not daily driver) standard farb standard drop links with poly bushes poly bushed wishbones with white line anti lift kit standard toyota ball joints -2 deg front camber 1mm toe in rebound varies springs 8 kg front 6 kg rear poly bushed rear beam whiteline pan hard rod whiteline adjustable rarb set to max With good quality tyres semi slicks for best results but I like 1B road tyres like Yoko AD08r or Toyo R1R Quote
Amjad Posted May 20, 2014 Author Posted May 20, 2014 Kinda similar to mine then! Are those spring rates a bit hardcore on the road? Will have polybushed wishbones with ALK on the car in a few weeks hopefully Quote
Mad Mike EP82 Posted May 21, 2014 Posted May 21, 2014 Kinda similar to mine then! Are those spring rates a bit hardcore on the road? Will have polybushed wishbones with ALK on the car in a few weeks hopefullyYes n no sum roads are ok Quote
Amjad Posted May 21, 2014 Author Posted May 21, 2014 Ah okay! Tried F20 R15 yesterday, not bad. There's a little more flex than I'd like up front but hopefully the few mods I have coming in the next few weeks will reduce that. As for the tyres, URS3s really are great for the price! Quote
