rwdrev Posted May 15, 2014 Posted May 15, 2014 can i use the original crank sensor from the 5e with a 32 tooth trigger wheel to run my ecu master standalone along with a trigger signal from the dizzy? Quote
mech5107 Posted May 18, 2014 Posted May 18, 2014 Your 5e has a stock crank trigger? Should be a non distributor engine then. You can run batch injection and wasted spark with only the crank sensor (I suppose your crank trigger has a missing tooth). If you add a can home signal you can go full sequential injection. Quote
rwdrev Posted May 18, 2014 Author Posted May 18, 2014 taken from another thread but this is the crank sensor idea. 32 teeth and a blank section, then take a pin out for using coil on plug from a gt dizzy?!? Quote
mech5107 Posted May 18, 2014 Posted May 18, 2014 The stock dizzy already has the single tooth wheel needed. But even without the dizzy, you can run coils on plug just in waste spark setup Quote
klyfax Posted June 1, 2014 Posted June 1, 2014 (edited) Hehe that's my engine :-)Some ECU can run with it as it is. Some needs the wheel to be a normal 36-2 wheel. Others can't run on a 36-2 wheel. I use MS ecu and it is not very happy with 36-2 at all. Omex claims that they works with Toyota 36-2 wheel.I grinded my wheel to 18-1. That works with my ecuEDIT: Changed all 32-2 to 36-2 Edited June 2, 2014 by klyfax Quote
klyfax Posted June 1, 2014 Posted June 1, 2014 (edited) First try to get the ECU to understand the wheel. It did understand it, but MS is not happy with 36-2 wheels in general. Second try, now MS is very happy with the wheel.EDIT: Its a 36-2 wheel, not 32-2 Edited June 2, 2014 by klyfax Quote
5e colin Posted June 1, 2014 Posted June 1, 2014 ^^^^ nice1 so its just every other tooth has to go on it thanks Quote
rwdrev Posted June 1, 2014 Author Posted June 1, 2014 this is a differnt tooth pulley to what i have, mines like the 1 in the first pic, but the 2nd pic is 34 tooth Quote
klyfax Posted June 2, 2014 Posted June 2, 2014 (edited) Its the same pulley on all the pics. First is how Toyota made it. 2 is where the large tooth between 34 and 1 is grinded away, so it becomes a normal 36-2.EDITED ALL POST FROM 32-2 TO 36-2 Edited June 2, 2014 by klyfax Quote
rwdrev Posted June 2, 2014 Author Posted June 2, 2014 oh... i get ya now. so if i get 5 more teeth machined in and remove 1 and hey presto. looks like i have to get myself a new oil pump to house the sensor Quote
klyfax Posted June 3, 2014 Posted June 3, 2014 If you dont have the oil pump and sensor, dont go down this road. Take a normal 36-1 trigger wheel and mount on the belt pulley and then mount a sensor to read it. It is faster, cheaper and more easy to do.I only tried this because i wanted a 100% standard toyota system. After I mounted it, I found out that many ECU can't work with this set up.There are some guys here at UKSO that already have done a normal 36-1 wheel conversion. Quote
triple j Posted June 3, 2014 Posted June 3, 2014 I done a mod on my dizzy for a 12-1 wheel, i never tested it yet and am not sure if i will because i just ordered a 36- wheel to mount on my crank, its the best optionMy ms has only one vr sensor thats the reason for the dizzy mod, but going the crank trigger wheel is the best hassle free option. Quote
mi16chris Posted June 3, 2014 Posted June 3, 2014 I done a mod on my dizzy for a 12-1 wheel, i never tested it yet and am not sure if i will because i just ordered a 36- wheel to mount on my crank, its the best optionMy ms has only one vr sensor thats the reason for the dizzy mod, but going the crank trigger wheel is the best hassle free option. I've done this before it dose work ok depending on your ecu Quote
