can a fucked lambda cause a dead spot at low speed? my glanza has a problem where if youre driving at low idle like 2000rpm or lower put your fut down and the car feels like sonething is pulling it back then boost licks in and youre off. i got decat magnecore blitz ecu. it started out of the blue. at high speed it goes perfect but low speed and revs its sluggish and is dead until boost kicks in.
also where can i get a new lambda sensor
Unplug your lambda sensor and take it for a spin. If the problem disappears you can either buy a new lambda or buy a wideband and do as above to use it as your lambda. That way you can keep an eye on your fuelling in the future
