My gearbox is clonking in 2nd 3rd 4th and 5th at low speeds it's quite loud but when you speed up it's much quieter on the motoway it's preety much silent ? Has anyone had this problems before and what was it
My oem lsd doesn't make any noises at all at any speeds?? Defo check oil again or change it if needs be
It never used to until a few weeks back I only put it at Christmas so oil was fine I dropped it all out and put fresh oil in last week still the same so it's not beacause low oil or anything
pop off drive shafts and take a look through the hole, or shake the drive shafts to see if there is any play on the g-box side, sounds like the bearings on the diff possibley, seen it before
