Hi I'm gettin a ct9 hybrid at the moment I have
Front mount
Decat
5zigen straight threw
Magnecor ht leads
Stainless mani
Standard ct9 with turbo meshed
Hks actuator runin 0.75
Hks fcd
Standard ecu
I ran 165bhp n 195torque before I changed mani and put leads on
Wat else to do I need to run a hybrid?
management is key - fcd is a ticking time bomb get rid of the FCD and go for a plug n play ecu and then turn it up to 1bar.
should be close to 200bhp on stock ct9 and probably 10-15 more bhp with a hybrid.
Also change your fuel pump
Right I see have been given a hybrid u see but haven't got the money ATM for a ecu wud it run okay if just put on my setup already
yes it will run fine but dont increase the boost untill you get proper management and a FCD is not needed if your only running 0.75 bar of boost.
Edited by H_D
you will see a small difference but hybrids are more noticeable at the higher rev range where the stock ones usually run out of puff
i wouldnt run more than .8 bar and i would not bother spending money on a mapable ecu for the sake of a hybrid.
fcon is a good ecu but will need mapping.
if it helps i am making the trip to Tuning Developments on the 28th of June. to get my ECU Mapped E Manage, should unlock my power potiental, i have pretty much the same supporting mods as you,
let me know if you want to Join me?
