Sturmster Posted May 21, 2014 Share Posted May 21, 2014 Hi I'm gettin a ct9 hybrid at the moment I have Front mount Decat 5zigen straight threw Magnecor ht leads Stainless maniStandard ct9 with turbo meshed Hks actuator runin 0.75Hks fcdStandard ecuI ran 165bhp n 195torque before I changed mani and put leads on Wat else to do I need to run a hybrid? Quote Link to post Share on other sites
H_D Posted May 21, 2014 Share Posted May 21, 2014 management is key - fcd is a ticking time bomb get rid of the FCD and go for a plug n play ecu and then turn it up to 1bar.should be close to 200bhp on stock ct9 and probably 10-15 more bhp with a hybrid.Also change your fuel pump Quote Link to post Share on other sites
Sturmster Posted May 21, 2014 Author Share Posted May 21, 2014 Right I see have been given a hybrid u see but haven't got the money ATM for a ecu wud it run okay if just put on my setup already Quote Link to post Share on other sites
H_D Posted May 21, 2014 Share Posted May 21, 2014 (edited) yes it will run fine but dont increase the boost untill you get proper management and a FCD is not needed if your only running 0.75 bar of boost. Edited May 21, 2014 by H_D Quote Link to post Share on other sites
Sturmster Posted May 21, 2014 Author Share Posted May 21, 2014 Okay cheers mate will I see a difference Quote Link to post Share on other sites
H_D Posted May 21, 2014 Share Posted May 21, 2014 you will see a small difference but hybrids are more noticeable at the higher rev range where the stock ones usually run out of puff Quote Link to post Share on other sites
Sturmster Posted May 21, 2014 Author Share Posted May 21, 2014 Wat boost cud I run with out ecu? And are hks fcon sz ecu any good? Quote Link to post Share on other sites
H_D Posted May 21, 2014 Share Posted May 21, 2014 i wouldnt run more than .8 bar and i would not bother spending money on a mapable ecu for the sake of a hybrid.fcon is a good ecu but will need mapping. Quote Link to post Share on other sites
Bristol glanza Posted May 21, 2014 Share Posted May 21, 2014 if it helps i am making the trip to Tuning Developments on the 28th of June. to get my ECU Mapped E Manage, should unlock my power potiental, i have pretty much the same supporting mods as you, let me know if you want to Join me? Quote Link to post Share on other sites
