AndyT Posted December 24, 2005 Posted December 24, 2005 I changed my gearbox oil yesterday, drained it with the 24mm bolt on the bottom of the box, and filled it through the 17mm bolt in the top of the box. I put in 3 litres.Today when i was under the car i noticed another 24mm bolt in the box, sort of towards the front of the car on the side of the box. Is this the fill level bolt???Should i park the car on the flat and take that bolt out to let the excess drain? I dont want to have overfilled it and fucked seals etc Thanks ;) Quote
Ivan Posted December 24, 2005 Posted December 24, 2005 Yes, undo the top 24mm bolt and let everything drain otherwise the excess oil will bust your seals and possibly do more damage.Regards,Ivan Quote
scutch0 Posted December 25, 2005 Posted December 25, 2005 yeah, as ivan said, it is.you'll wanna drain out the exess oil mate, i seem to remember mine took 2 litres...Rich. Quote
AndyT Posted December 25, 2005 Author Posted December 25, 2005 Done now ;)About 1/2 a litre came outThanks again Quote
