ep91 factory immobiliser, 5e ecu
Hi
I am currently collecting the bits to complete my project
A 5e into the ep91 currently running the 4efe uk 98 model
I will be using the 5e loom and 5e ecu all from a jdm sped car, no immobiliser
my current car has the toyota factory immobiliser, is the key coded to the ecu ?
what problems may i face if the 4efe ecu is removed and replaced with the 5e ecu or is the immobiliser just requires the signal from the key which is that ring around the ignition barrel ?
thank you
