Hi
I am planning to do a conversion and drop a 5efhe into the ep91 uk 4efe non (acis)
5e ecu has on the 16 plug (pin 1) switched battery power (12v)
the 16 plug on the 4efe wiring these is no switched battery power (12v) on the pin 1
surely some one has ran into this has the 4efte also has the switched.........(12v)
I am guessing from other talk on this it has something to do with the dizzy coil, 4efe has internal coil and 5e has external coil maybe ?
or does it have something to do with the efi relay ?
Hi chris, i have the full loom and all the sensors that came off the 5e and ignitor and coil, all still attached with all vac pipes, why not use it ?
the loom and pins is really identical but just the 1 pin which the 4e hasnt got i nned to make it owrk on the 5e i thinks
