raddys1 Posted May 27, 2014 Posted May 27, 2014 Hello fellow ukso's, I have just purchased a standard 4efte with 73k and I have here for you the compression test results.. can anyone verify if these are any good?No.1 150No.2 158No.3 165No.4 157Thanks in advance Quote
Zeldoz Posted May 27, 2014 Posted May 27, 2014 Wouldn't overly worry at those results.. But Cylinder 1 is slightly lower.. Someone might advise better Quote
raddys1 Posted May 27, 2014 Author Posted May 27, 2014 Just used a compression tester done each cylinder at a time took the king lead off and turned the engine over Quote
fiddlersport Posted May 27, 2014 Posted May 27, 2014 was the throttle body open when you did the test matey ? Quote
