Sandham Posted May 29, 2014 Share Posted May 29, 2014 Hi, i recently fitted an exedy organic clutch to my car with no problems however the car had a very high biting point. I attempted to bleed the clutch and found the fluid to be very mucky but didnt have enough fluid to drain it completley and put fresh in.. Stupid move!Since doing this the clutch has lots more freeplay in the pedal (about halfway to the floor) and the bite is very low. But doesnt slip and selects gears fine.Just looking for advice as to what to do to get my clutch adjusted and setup properlyThanks Quote Link to post Share on other sites
daniel_g Posted May 29, 2014 Share Posted May 29, 2014 You'll just need to bleed it completely until there is no air in the system. Check the pedal. If you still dont like it then there is a threaded rod at the top of the clutch pedal, this can adjust out some free play and give a better clutch feel. Quote Link to post Share on other sites
Sandham Posted May 29, 2014 Author Share Posted May 29, 2014 Thanks ill give it another go tomorrow with a pressure bleeder and run it through till clean fluid comes out Quote Link to post Share on other sites
