Adam M Posted June 4, 2014 Share Posted June 4, 2014 Hi ukso I can't find if my ecu is standard or notFirstley what power can a standard ecu produce?As my car defo feels 200 bhp if not more ( have no printout)Secondley the ecu just has the standard sticker on it no aftermarket logo or stickers all i have are the codes which are these:Toyota89661-10200211000-4290 12v26p 16p4e fteP - -Reason is the tuner needs to know or shall i show him the ecu and see what he thinksIf anyone can shed light please doThanksAdam Quote Link to post Share on other sites
morgey Posted June 4, 2014 Share Posted June 4, 2014 Open it up. Stock has a single board. Aftermarket has a secondary.But be warned some ecu's are said to have a light sensing chip that goes blank I've opened (apparently)Stock ecu revs to 7700Speedlimiter at 112mphBoost cut at 0.85 barBoth the later can be removed with a speedo convertor and a Fcd Quote Link to post Share on other sites
Adam M Posted June 4, 2014 Author Share Posted June 4, 2014 Thanks allot for the reply mate i'll have a look!Mine is running about 11-12 psi so 0.85ish barLimits at like 8500 and does about 120-130 mph i think so must be aftermarket i guessI'll check thanks for the info massive help! Quote Link to post Share on other sites
morgey Posted June 4, 2014 Share Posted June 4, 2014 With rpm that high I would assume so. But yeah if you open it up you will either see a board with a 2nd one on top a bit like this http://img.photobucket.com/albums/v229/TTJ/JamECU_2.jpgThat means it's non standard Quote Link to post Share on other sites
klyfax Posted June 5, 2014 Share Posted June 5, 2014 Stock 4e-fte ECU revs to 7200 rpm. Quote Link to post Share on other sites
Zeldoz Posted June 5, 2014 Share Posted June 5, 2014 Maybe a plug n play! Quote Link to post Share on other sites
morgey Posted June 5, 2014 Share Posted June 5, 2014 Stock 4e-fte ECU revs to 7200 rpm.I stand corrected. I don't have a 4e or 5e so Quote Link to post Share on other sites
karl. Posted June 5, 2014 Share Posted June 5, 2014 Stock 4e-fte ECU revs to 7200 rpm. EP82 is 7200 and EP91 is 7500 Quote Link to post Share on other sites
klyfax Posted June 5, 2014 Share Posted June 5, 2014 Damn, now I stand corrected Quote Link to post Share on other sites
Adam M Posted June 5, 2014 Author Share Posted June 5, 2014 (edited) . Edited June 12, 2014 by Adam M Quote Link to post Share on other sites
