ryan22laird Posted June 4, 2014 Share Posted June 4, 2014 Hi guys needing some help will a 5e clutch fit on my 4e engine ? Quote Link to post Share on other sites
ryan22laird Posted June 4, 2014 Author Share Posted June 4, 2014 Can anyone help Quote Link to post Share on other sites
russ78 Posted June 4, 2014 Share Posted June 4, 2014 pretty sure to use a 5e clutch you will need a 5e flywheel to go with it bud Quote Link to post Share on other sites
richardc9052 Posted June 4, 2014 Share Posted June 4, 2014 5e clutch will fit on a 4efe but not a 4efte Unless you fit a 4efe flywheel to your 4efte.. If you already have a 5e paddle clutch it's worth it Quote Link to post Share on other sites
ryan22laird Posted June 4, 2014 Author Share Posted June 4, 2014 Thanks guys a just tried the 5e clutch on a 4e flywheel and it fits also tried the 5e flywheel on to and it fits but the previous owner has had the fly wheel drilled so the holes fit Quote Link to post Share on other sites
richardc9052 Posted June 4, 2014 Share Posted June 4, 2014 you need to finish the engine code lol... 4efe or 4efte? the 5e clutch wont fit a 4efte flywheel so whatever engine you have your running a 4efe flywheel Quote Link to post Share on other sites
