Lawless Posted June 7, 2014 Posted June 7, 2014 Picked up my gt today after a 3 week wait an the temp gauge is moving up and down when I'm on an off the throttle I have been advised to take the thermostat out as a temp measure so I can use it For now but want a second opinion is it safe to dot his or is anyone else not running a thermostat Will get one ASAP but it's the weekend ! Quote
Gainzy Posted June 7, 2014 Posted June 7, 2014 Not worth the risk imo just wait till you get one sorted, few days or risk an engine failure just not worth it Quote
richardc9052 Posted June 7, 2014 Posted June 7, 2014 Basically its overheating on throttle. so are you running high boost? running lean? Retarded timing? Head gasket gone? Leak in coolant system causing not to pressurize? What happens on idle? Quote
Lawless Posted June 7, 2014 Author Posted June 7, 2014 Seems fine on idle and was fine before it went in for repair Took it out for a blast earlier and seems to of cured itself I'm hoping it was just the thermostat sticking Quote
