Jhandy Posted June 11, 2014 Posted June 11, 2014 Make: toyotaModel: hilux 4runnerMileage: 110kYear: k reg Price: 1400 onoLocation:bracknellHere is my 4 runner not had it long. Bought it to tow with. But changed plansSpecsExteriorPaintwork is rubbish it has rust starting to appear on the rear archesIt has no rust under neath what so ever. I have completly undersealed this myselfWind deflectors fitted It's been Jacked up on a 4" body lift and rolls on 10" rims The rear tail gate window works but is slow.InteriorIt's very clean for its age and everything works. It has soft and hard suspension that still worksIt has new boot carpet that I put in. Not the greatest job. But is better than a oil drenched old thing I have added extra 6x9 speakers to the rear so you can here better.I have also installed keyless entry to this fully working. Flashes hazards on exit and entry. And has a blue led when locked. can have a siren fitted Mechanical.Engine is sound recently had new Cambelt. The diesel pump started to leak diesel. So I removed and changed 2 sills only 1 was leaking but I changed both. That was about 150 miles ago.It has a mushroom filter sounds awesome on boost.Recently changed the upper and lower ball joints on the n/s/f and the n/d/f track rod end. All this vehicle needs is 4 front c.v boots that is allNew partsBall joints rear fog lightWind deflectorsBoot carpetSpeakers and 6x9 boxesCambelt Rocker cover gasketKeyless entry Coolant bleed valves.It's a 2.4 turbo diesel automatic.Low mileage at 110k mixed between mph and kmh so it's really low for its age.It's not the most economical thing in the world. But hey us lot should be use to that.Please only serious buyers. Had a lot of messersHas a couple months mot and tax left so van be driven awayThis is a cheap car/truck Logbook/v5 is present and in my name.Contact 07584306516 as of 17th June as I'm in Florida or Pm and I will get back to you asap Quote
Jhandy Posted June 11, 2014 Author Posted June 11, 2014 Cheers bud. Is a fun truck. Green lanes well to Quote
Jhandy Posted June 12, 2014 Author Posted June 12, 2014 Bump it up. Would like this gone asap so I can start my new build. Will listen to offers Quote
