TD04HYBRID Posted June 12, 2014 Posted June 12, 2014 (edited) Hi Guys, After the last 7-8 months of owning the car and near enough changing everything on it i have finally just booked my mapping session ...... Looking forward to it and hopefully all the hard work will pay off with them figures. Not too sure what to expect though in terms of power. what do you guys reckon? Spec List Engine:74.5 mm ross forgedpauter rodspolished and knife edged crank lightened pulleyall new bearings and seal new cam belt2mm Multi Layer Head Gasket Fueling470cc Injectors255l Walbro Fuel PumpTD High Flow Fuel RailSard FPR CoolingAutoBahn Front Mount IntercoolerAlloy Civic RadRelocation Air Filter Kit(Come out just behind grill) Turbo:TD04 Hybrid Lateral PerformanceFull HKS Hi Power Exhaust SystemUp Rated Exhaust HangersZisco Cruise Manifold Externally GatedTurbo Smart WategateZisco Screamer PipeZisco Decat Transmission:spec 6puk paddle clutchTD Light weight flywheelC's Short Shifter Electronics:E-Managed UltimateDepo Racing Oil Temp GaugeDepo Racing Oil Pressure GaugeDepo Racing Water Temp GaugeStart/Cut off switchFan toggle switchFuel pump toggle switchHKS EVC 6 Boost Controller Chassis:6 Point Carbing Roll CagePolycarbonate SunroofBMW E30 WheelsCusco Front Strut BracePoly Engine and gear box MountsWhite Line Front Anti Roll BarWhite Line Rear Anti Roll BarBC CoiloversRSR Pan Hard Rod Brakes4 Pot WilwoodsBraided LinesVented and grooved discYellow pads Edited June 12, 2014 by TD04HYBRID Quote
Socks Posted June 12, 2014 Posted June 12, 2014 The usual is 270-285bhp at 1.4bar of boost It will be fun to drive when you get it back fella! Quote
TD04HYBRID Posted June 12, 2014 Author Posted June 12, 2014 That good engine been built for 2 bar! turbo rated to 1.8bar Quote
TD04HYBRID Posted June 12, 2014 Author Posted June 12, 2014 Be nice to see what it makes but will be turned down on track Quote
TD04HYBRID Posted June 12, 2014 Author Posted June 12, 2014 The usual is 270-285bhp at 1.4bar of boost It will be fun to drive when you get it back fella!I have it here fella done all the work myself so will be taking it there for mapping can't wait nervous though as puts a lot of strain on it Quote
TimD Posted June 12, 2014 Posted June 12, 2014 Mine is being mapped by Will at RDT on the 27th.. Pretty nervous too, I'm not really that bothered what mine makes. Hoping to have it setup for between 12 and 15psi on a Tongs Hybrid turbo. Quote
TD04HYBRID Posted June 12, 2014 Author Posted June 12, 2014 Mine is being mapped by Will at RDT on the 27th.. Pretty nervous too, I'm not really that bothered what mine makes. Hoping to have it setup for between 12 and 15psi on a Tongs Hybrid turbo.Yeah it is a nervous feeling! For track it will on be on the same as you 12-15 psi! But it will be nice to see what power is there if needed gives a bit of satisfaction on what you've built Quote
