thorpy36 Posted June 22, 2014 Posted June 22, 2014 As above guys,I need a rear anti roll bar kit new or used as long as it functions properly
thorpy36 Posted June 22, 2014 Author Posted June 22, 2014 I'll still need all the bushes and u bolts and that though won't i ?
Uzzy@ID-Workz Posted June 22, 2014 Posted June 22, 2014 We have them available on our website matehttp://www.id-workz.co.uk/index.php?main_page=product_info&cPath=3_1118_8_12&products_id=433
richardc9052 Posted June 22, 2014 Posted June 22, 2014 yeah you still need to buy the clamps and stuff... you should be able to get a transit connect arb for £20..
Dylanfarrell Posted June 25, 2014 Posted June 25, 2014 yeah you still need to buy the clamps and stuff... you should be able to get a transit connect arb for £20.. Any pictures or more details please?
richardc9052 Posted June 25, 2014 Posted June 25, 2014 What details do you want? theres not much to them..
Dylanfarrell Posted June 25, 2014 Posted June 25, 2014 What details do you want? theres not much to them.. What you got the end links off of and the brackets to hold.to the rear beam if you could.
richardc9052 Posted June 25, 2014 Posted June 25, 2014 The end links where alfa romeo links, they are quite thick so where cut, extended and welded back. There are longer links about that you could use but youd have to look into it. The bushing brackets are the ones of the transit and u clamps over the axle bolted through the brackets.
Dylanfarrell Posted June 25, 2014 Posted June 25, 2014 The end links where alfa romeo links, they are quite thick so where cut, extended and welded back. There are longer links about that you could use but youd have to look into it. The bushing brackets are the ones of the transit and u clamps over the axle bolted through the brackets.Gent! Cheers for the info
