AMartin Posted June 29, 2014 Share Posted June 29, 2014 Hi all, just trying to remove my rear calipers off my Glanza as the rear sliders have seized, how do I go about disconnecting them just disconnecting the brake line and then where do I disconnect the parking brake? Do I also have to clamp the hoses or anything? Any help would be much appreciated. Cheers Quote Link to post Share on other sites
neilgt Posted June 29, 2014 Share Posted June 29, 2014 Yes disconnect the flex pipe and clamp if poss, and were the handbrake cable goes on the caliper there's a little clip that goes through a pin remove both of them then just unbolt. That is how they are on my ep82 hope that will help you Quote Link to post Share on other sites
AMartin Posted June 29, 2014 Author Share Posted June 29, 2014 Thanks mate, gonna give it a crack inabit. If anyone else has any tips that would be great. Thanks again Quote Link to post Share on other sites
AMartin Posted June 29, 2014 Author Share Posted June 29, 2014 Also would it be adequate just to block the pipes instead? Quote Link to post Share on other sites
neilgt Posted June 29, 2014 Share Posted June 29, 2014 You can try Quote Link to post Share on other sites
WallaceGlanza Posted June 30, 2014 Share Posted June 30, 2014 Jam the brake pedal down - against the seat with a piece of wood to stop leaks. ;) Quote Link to post Share on other sites
