ok, I'm about to throw a hissy fit !
Need to change the rear pads and wheel bearing.
Got the caliper off no problem but can I get the carrier off, can I feck !
The carrier bolts are solid and look to be rounded off.
14mm socket just turns, 13mm dont fit on..
How the hell do I get them out now so I can do the bearing ?
blowtorch till it's red
hammer
hammer
quickly get a spanner on it and hit it (if it is fully rounded, smack the 13mm spanner on and replace the bolt after)
Edited by Jamie5414
6 sided 14 mm did the trick and that is why I normally leave the spanner work to others ! :D
Which way round does the inner bearing go on an Glanza V ABS model ?
With the outer race: (Surely its this way with the outer race ?)
https://onedrive.live.com/redir?resid=14D8D930C1560B4%21784
Without the outer race: (This is how it was !)
https://onedrive.live.com/redir?resid=14D8D930C1560B4%21783
Edited by MarkyG
Well it looks like its without the outer races on both inner and outer bearings ie. it uses the tapered flange on the disk. Thats the only way they fit.
The hub nuts...... finger tight plus a quarter turn ???
