Turbo Goose Posted July 10, 2014 Posted July 10, 2014 (edited) Can you machine astra 1.7 cdti discs to fit st185 twin pots or can you only mod them to fit the late spec 185 single pots?Thanks guys Edited July 10, 2014 by Haresign Quote
Turbo Goose Posted July 10, 2014 Author Posted July 10, 2014 (edited) . Edited July 10, 2014 by Haresign Quote
turbo Grant Posted July 10, 2014 Posted July 10, 2014 You can machine the inside of the bell out on the 256mm astra discs so they fit over your hubs. Then the twin pots will bolt straight on Quote
5e colin Posted July 10, 2014 Posted July 10, 2014 you knead apec disk dsk 2188 and take 1 mm from inside and cut down to 260mm Quote
Turbo Goose Posted July 10, 2014 Author Posted July 10, 2014 Just sourced sum single pots so all is good now. Thanks guys! Quote
