Aamir Posted July 12, 2014 Posted July 12, 2014 Hi all,Been working on my car and it runs like shit. Did a diagnostics test and found error code 31, which is MAP sensor. Removed my current one and put a different one on and still have the same problem. Anyone have any idea of what could be the problem? If I unplug the TPS and MAP sensor it runs a lot better. So I'm guessing the TPS might be broken?Aamir Quote
daniel_g Posted July 12, 2014 Posted July 12, 2014 Id start by setting the TPS up properly with feeler gauges and a multimeter. And replace the vacuum line to the MAP sensor. Quote
Aamir Posted July 12, 2014 Author Posted July 12, 2014 Id start by setting the TPS up properly with feeler gauges and a multimeter. And replace the vacuum line to the MAP sensor.Thank you, I'll replace the vacuum tomorrow and I'll have to try find a TPS. Are the TPS on a Paseo the same as the Starlets? Aamir Quote
