Swapping exhaust blades on td04
Hi guys, ive got a tf035 turbo. I bought a rebuilt td04 core/chra thinking it would fit.
Turns out the exhaust side blade wheel is larger.
Could i just swap the tf035 blade wheel for the td04 one and fit the rebuilt chra into the tf035 or would this cause it to be unbalanced?
Or just risk it for a biscuit.
Thanks guys
Dan
I know it doesnt fit buddy thats my point lol. Ive got a td04 chra sat in my room and wondering if i fit the tf035 exhaust wheel it would be ok or would it be unbalanced. Im tempted to buy yours at this point. Already wasted over 120 quid
Edited by Haresign
It will be unbalanced if you remove the wheel yes, and it's very difficult to reassemble it the exact same place. It'll also have a different indentation in the bearing housing where the wheel sits the td04 one will be larger obviously. Best bet would be to replace the wheel with the correct one. Compressor wheel are cheap to replace. Do it cheap and it'll more than likely cause issues.
