abbie Posted July 16, 2014 Posted July 16, 2014 looking for a company who makes them ? any one have any info for me ?thanks in advance Quote
AdamB Posted July 16, 2014 Posted July 16, 2014 Can get regrinds from places like Pipercams, but regrinds are a waste of time, plus a set of billets over here would cost an arm. Ivan Tighe are the best and have plenty of off the shelf specs to choose from. Whats your engine spec? 99.9% of people don't need cams or choose the wrong cam specs and it makes the engine worse. Quote
abbie Posted July 16, 2014 Author Posted July 16, 2014 (edited) il email ivan Edited October 8, 2014 by abbie Quote
AdamB Posted July 16, 2014 Posted July 16, 2014 (edited) Wouldn't really need cams on that spec engine really, although if you are chasing numbers then stick with stock duration and go for more lift, something around 8.8mm on the intake and 9.2mm on the exhaust.I'd be putting the money towards a custom intake manifold and larger throttle body rather than cams tbh, turbo engines are the most fussy when it comes to cam specs and manufacturers spend millions on R&D, I don't see the need to change it. Edited July 16, 2014 by AdamB Quote
5e colin Posted July 16, 2014 Posted July 16, 2014 there is this member on here with the cynos he does rallycross with it , he has a link for custom 1s 200£ or something ??? Quote
AdamB Posted July 17, 2014 Posted July 17, 2014 Their probably regrinds, think you can get the cams reground for £160. Problem then is getting the correct valve clearances as they are a bastard to do! Quote
turbo Grant Posted July 17, 2014 Posted July 17, 2014 Regrinds are easy to shim up with custom under bucket shims Quote
