manifold is WEPR...but god only knows who made that little pipe. just FYI...we provided a few Evolution manifolds couple of years back with a waste gate relocation pipe. these Evo manifold will have the w.gate outlet comming out straight. the Evo manifold generally come with the waste gate out let pointing up which allows you to bolt the f38 tial directly on to the manifold. fitting it directly on to this manifold may cause fouling with the upper rad hose mate. you could get someone to make up a small F38 to MVS band adapter and fit the newer smaller tial 38mm. or simple just a small flange to waste gate extention angled slightly down..just enough to clear the upper hose. hopes this helps bro...:)
