Hi guys, i know eveyone says you can run a td04 without waterlines but do i simply stick a couple of m12x1.25 bolts in there and hey presto or do i wack a little oil in there to keep it lubed then put bolts on. Or does it simply run dry? Smoked a little from the water outlets earlier probably just burning a bit of excess crap outa there
Thanks, dan
Also, where the water outlets come out from the engine ive just raken one pipe off and looped the other round is that ok?
And when removing the water pipes off yhe engine i lost about 1 to 2 litres of water, with this automatically re bleed itself from the rad then just a case of topping it up?
Edited by Haresign
