federalman Posted July 19, 2014 Posted July 19, 2014 5th gear has started to pop out under accleration, so I will be replacing it at some stage. Does anyone have the standard part numbers and what bits I will need. Also a starting point on where 5th is located inside the gearbox would be handy. Cheers, matt Quote
pockrockgtti Posted July 19, 2014 Posted July 19, 2014 You will probably need the 5th gear, hub, and synchro.http://japan-parts.eu/toyota/jp/1999/starlet/ep91-agmqy/4_121150_006_/powertrain-chassis/3305_transmission-gear-mtm#33336A Quote
Broony Posted July 21, 2014 Posted July 21, 2014 Things you need: Shift fork- 33214-10022Hub Sleeve - 33395- 120115th gear - 33036-12011Needle bearing - 90364-24006Synchro ring - 33369-12030Spacer - 90560-25006Snap ring - Check yours and order the number stamped on it as theres a few to choose from Im doing this on mine so hope this helps Quote
Broony Posted July 21, 2014 Posted July 21, 2014 came to around £295 but i got mine at trade price, shy kids get no cake and all that Quote
Broony Posted July 22, 2014 Posted July 22, 2014 (edited) Just confirmed the order, hope these fix it !! fingers crossed Edited July 22, 2014 by Broony Quote
federalman Posted August 8, 2014 Author Posted August 8, 2014 Lovely cheers guys hopefully i can get this sorted soon Quote
