Hey guys,
The bite on my clutch is really high, to the point where I can change gear smoothly by depressing the pedal about 5mm. There's also a lag between revs increasing and speed increasing, ie I floor the throttle and engine noise goes way up but speed catches up quite gradually. Oddly, though, the car will stall out perfectly well if I let the clutch out when still. Wouldn't clutch wear cause some slipping before stalling?
I've never had any dealings with hydraulic clutches before, could it be a problem with the fluid? Or do I need a whole new clutch assembly?
Cheers,
Josh
