Ollieh17 Posted July 23, 2014 Posted July 23, 2014 Recently fitted my TD04 and have an oil leak that seems to be coming from the return. I reused the old gasket so suspect that could be the issue. However there's more oil leaking than id expect from just a shoddy gasket? Dripping Oil is visible on the silicone return after a short drive or idling shortly, is there anywhere else the oil could be coming from? something more serious possibly? Quote
glanzatd04l220 Posted July 23, 2014 Posted July 23, 2014 check that the oil feed pipe is tightened up mate. kevin Quote
TD04HYBRID Posted July 23, 2014 Posted July 23, 2014 Yeah oil feed pipe will be leaking had the problem on mine nipped it up more and problem solved Quote
Ollieh17 Posted July 23, 2014 Author Posted July 23, 2014 oil feed pipe is definitely tight with the two copper washers on, check that one twice Its definitely dripping from the bottom of the turbo somewhere, guessing return. Have a new gasket to fit so hopefully it is just that. Is it possible to remove the oil return and refit without taking everything off the car again? Quote
TD04HYBRID Posted July 23, 2014 Posted July 23, 2014 oil feed pipe is definitely tight with the two copper washers on, check that one twice Its definitely dripping from the bottom of the turbo somewhere, guessing return. Have a new gasket to fit so hopefully it is just that. Is it possible to remove the oil return and refit without taking everything off the car again? yes you can mate Quote
