jack_wetone Posted July 27, 2014 Posted July 27, 2014 okay well i got a lot to think about and a lot of spare time soon to as im loosing my license and so im doing a 5efe conversion i am thinking of fitting the hole lot as in engine and gear box in 1 go will this work ? is it better with paseo box or is it same as starlet ? and also wana fit the 5efe ecu im not gona reprogram i was just thinking of swoping the hole lot as in ecu chip reader and barrel any one done this ? as for the 5efe it has done 140k and burns oil so im gona rebuild it, i was just going to put a set of valve stem oil seals and rings in there but whilst im in there are there anymods i can do i want just toyota parts not aftermarket (budget build) i know about 5efhe cams but what about pistons what e series engine has the best pistons as such and can i fit them and what about heads is there a best head ? that allows the best flow or am i better off port and polishing? i am aslo gona do the obvious and put corolla manifold inlet and outlet 4branch in and 4-2-1 out and make/buy exhaust system any advice on any of the that would be great thanks oh and a 6 speed if i can get one! cheap enough!! Quote
5e colin Posted July 27, 2014 Posted July 27, 2014 just fit the 5e complete and run it of the 4efe electronics and afterwards get it set up with a emanage bluu or safc / fpr combo no knead to go to complicated :) Quote
