So i have my car for just one week and when i press the gas pedal and the rpm raises around 5000 rpm the car starts to snook i changed spark plugs . Oil . Fuel filter and idk what else to do ... its a glanza 1998 4e turbo stock only thing i changed is the blow valve and placed a boost gauge
Snook? what do you mean by that? it stutters/judders?
When i trottle the meter goes to 6 psi and it stutters
and it stays stuck at 6 psi
6psi is nothing to worry about thats very low.. But your boost gauge could be faulty & your over boosting then hitting fuet cut causing the car to stutter/judder
That's a good call there, I'd try and swap out the boost gauge and see if it's says the same, 6psi is 0.4bar ( low boost ) normal boost is around 0.65bar
James
only thing i changed is the blow valve .. from stock to the hks one you can see in my build tread which one i mean ... for the rest everything is the same ... and its been doing it since i got the car
Get a video up
it was doing it before i changed spark plugs . so i changed it then to see if it fixed but stayed the same i went ngk BKR7E-11 5791 .. its not the same as in the car because most shops here didnt have the same ... the one that was in the car when i got it was ,,,,DENSO pk20r11 ... i live on a island so kinda hard get stuff hehe .. imma post a video when i get out ... also i just bought 4 spark plugs wire to see whats up
i just changed the spark plug cables .. and its not stuttering anymore .. but now when i go fast like race and i place my hand on the shift stick the stick vibrates i cant recall if its normal ? and im not calling it a case closed yet because im going for a few more spins later to see if it stays okay or goes back to stuttering
also now it goes to 10 psi smoothly no stutter nothing clean clean.... and thx for all the dedication and fast replies from you guys
Edited by mitsuruki
