After buying a forged engine on this 3 month ago turns out it was fucked bottom end was knocking so a Stripped it Down a originally thought it was the big end bearings that had gone turns out it was the main bearings there was nothing left of them so Av started again the engines now at my local engineering garage getting a fresh rebuild it's been there 2 weeks now should have it back next week hopefully the spec is
wiseco 74.5mm forged pistons
scat forged rods (block notched to fit them)
ACL racing big ends, mains & thrust bearings
Athenna 1.2mm metal headgasket (cruise 1.2mm re-usable headgasket in boot of car).
Valve springs
Valves lapped in
uprated valve stem seals
Magnecor ignition leads
NGK iridium heat range 8 spark plugs
Full engine cleand & painted
Crank reground
oversized bearings
That's the full spec engine wise Just need to run it in when a get it back what sort of boost & power can a run this at safe ?
