Dylanfarrell Posted August 4, 2014 Posted August 4, 2014 Do the EP82 dials plug into an N/A EP8x? Or do they need much work to fit? Quote
daniel_g Posted August 4, 2014 Posted August 4, 2014 The plugs are different at the back.Most simple way imo would be to use a GT dash loom.What engine and ECU are you using ? Quote
Dylanfarrell Posted August 4, 2014 Author Posted August 4, 2014 The plugs are different at the back.Most simple way imo would be to use a GT dash loom.What engine and ECU are you using ?To be honest at the moment just the stock 2E. Will be doing a a 4efe swap and have most of the wiring worked out so I only need to change the engine loom. Might just leave it and wire in a rev gauge some stage down the line rather than getting the cluster and plugs with pigtails and wiring them in that way Quote
