thorpy36 Posted August 5, 2014 Posted August 5, 2014 Hi all, I have a bizzare issue with an intermittent vibration coming from the front wheels through the steering rack.Symptoms:Wheel vibrates intermittently when going from 50MPH and above.Actions taken upto now:Balanced all four wheelsHad tracking doneChecked tyre pressures.The brake discs are only 1000 miles old and are high quality track spec discs. So I can't see those being warped.I am at a loose end now as where to turn next, any advice would be much appreciated ! Quote
morgey Posted August 5, 2014 Posted August 5, 2014 Wheels and discs seated on clean surfaces? Wheel nuts tight?No play in bearings/trackrods/ball joints/bushes? Quote
iamlegend Posted August 5, 2014 Posted August 5, 2014 check this out matehttp://www.ukstarletowners.com/topic/68520-steering-wheel-vibration-still-exists-sorted-woop/ had this exact same problem and it was never sorted in the end still had the odd vibration still going to put it down to the new discs I put in and its funny you say you have put new discs on....hmm Quote
thorpy36 Posted August 5, 2014 Author Posted August 5, 2014 I can see this is going to be a head ache job !! Quote
iamlegend Posted August 5, 2014 Posted August 5, 2014 I can see this is going to be a head ache job !! feel the pain it was a utter piss take!! how long has this been happening? ever since...?? new brakes fitted did it start etc?? Quote
thorpy36 Posted August 5, 2014 Author Posted August 5, 2014 No it's sort of just appeared from nowhere I have had the brakes on a while so I can't see it's them, I have a funny feeling I just need to change the track rod ends, ball joints and drive shafts all together. The. There is nothing it can be as everything is new then Gentle acceleration doesn't cause it it's only when I accelerate hard Quote
