Hey
Fitted my omp rep wheel ages ago
But need to get down to the problem on why my horn keep going off.
I had to unplug the horn to stop it.
The boss has 1 wire and I metal ring thing
On the back of the horn theres two spade connectors for the horn wire.
Does it mean I need a wired earth?
Posted Image
As you can see just the 1 wire
Any help would be great to get this sorted
Cheers
On mine it earthed itself out with the little metal bracket around the horn.
One spade connector is connected to earth (same as that metal bracket thing) so if its connected to that it will sound as soon as it comes in contact with the wheel. The other went through the button so that you had to press the button for it to sound. But you dont need to connect the other to anything.
Id say so. On the button mine had like a 3mm bar half way around it. That pushed agaisnt the boss/edge of the wheel and acted as the earth.
Put the wire on one spade and touch the frame of the button on something metal. If it sounds try it on the other one, hopefully that shouldnt sound unless you press the button.
