Had a bit snoop I can see the adjusters is it just a case of unscrewing them looks like I need a philips at a 45° to get in at them indicators were alot less hassle to get out.
I clip the wires and pull. Its a small ball in a small socket joint that just comes out. Not sure if there's a proper way but that's how I've always done it and never any issues.
Unclip*
Yea just the bulb connections. And pull each corner and they should just pop off. Am not sure if that's how its ment to be done but that's what I've done with all mine and try never got damaged
Just had a look at an image of those headlight adjusters yeah I can see what you mean a little white ball I will pull from the indicator side first cheers!
Managed to get them out with a bit of heave ho, pretty simple to be honest much easier taking the indicators out first :)
Aye its pretty concerning really ha. Am sure one of the lads from Aruba had his head lights nicked one night because they cost so much to get over there. You can actualy nick them with the car bottom locked ha
