Gumball89 Posted August 21, 2014 Posted August 21, 2014 Hi guys and girls just brought my starlet today pretty sure it's a ep91 1997 sportif if I lower it do I need to get a adjusteble panard rod ? Quote
GlanzaJ Posted August 21, 2014 Posted August 21, 2014 You'll need lowering springs or coilovers mate to lower the car , i think a panhard rod bar prevents the rear axle from moving side-to-side? Quote
5T4R7ET N/A Posted August 22, 2014 Posted August 22, 2014 After lowering your car the rear axle will be out of line, causing scrub on one side.the adjustable panhard rod will put it straight.So yes you need one Quote
Gumball89 Posted August 22, 2014 Author Posted August 22, 2014 Brilliant guys thank you very much Quote
Gumball89 Posted August 22, 2014 Author Posted August 22, 2014 Is the glanza suspension lower then normal sportif springs if so would it just be a case of changing the panard rod too ? Where can I get a cheep adjusteble panard rod from Quote
