Why not press it and find out??????!!!!!!!!!!! :p
How the hell are we gonna know what it does if you havn't pressed it?!
It's probably the rear fog same as on nearly every single import :p
Its gona be a fog light switch - as they dont come STD on EP91 tubby etc. like people are saying tho chap - why not press it and find out??
Just make sure u RUN as fast as possible when u do though :-p
i had the exact same problem if its in the area which is indentd so it actually looks like a factory switch then its the fog light for the rear but most people take em off as they look gay. big square light under your back bumper no thatnks. i dint know what that light was for for about 3 months.
Most people don't take them off, we wire them into the rear lights and lose the bottom set of the lights. Looks much better.
:agree: and also its very easy to do!
Bit of trivia for you - That little indentation was for the choke on earlier carb driven EP80's.
random so the gts (ep82)have the same dash. didnt know that
ive pressed it and im still here! :p it doesnt do any thing ive even checked for a rear fog light but its not there. :p
wot an arse! its a fog switch! i put the lights on and there was this crazy red light on under the wheel turns out its been wired into the rear lights! :D
