engine oil in the car needs changing and havent done it before, was just wondering where abouts is the drain bolt located under the car and how much oil would you recommend ?
Thanks in advance!
14mm oil drain bolt is located bottom of the sump, facing a bit backward.
If you are going to change the filter too, you will need approx 2.8litres of oil. 5w-30 or 10w-40 fully synthetic engine oil is recommended.
