stanbury211 Posted August 27, 2014 Posted August 27, 2014 As title says just want some info on what people have used for the oil return on there top mount kits, been advised not to use regular silicone hose as the heat will cause it to split? Thanks in advance Quote
Socks Posted August 27, 2014 Posted August 27, 2014 if the kits been designed well.. There will be a decent length metal pipe for the turbo return... To then allow the use of a silicone 90deg that is clear of anything majorly hot! Quote
stanbury211 Posted August 27, 2014 Author Posted August 27, 2014 It's a wepr manifold and down pipe kit, I haven't yet fitted my td05, so I'm guessing il need to get a longer metal return pipe made up? Cheers for the reply Quote
5e colin Posted August 27, 2014 Posted August 27, 2014 hydrolic pipe from engineers place with a heat sock around it Quote
stanbury211 Posted August 27, 2014 Author Posted August 27, 2014 Will give that a try thanks Colin Quote
5e colin Posted August 27, 2014 Posted August 27, 2014 its cheap to i got a oil feed made up out the stuf its the same stuff they use on those giant crains that run 150bar of pressure and are steel wrapped/belted inside they take some melting and abuse before they brake 35euros i payed so 28/30 pounds somewhere Quote
