Not a straight forward fit as we have found out today
What parts are exactly needed to fit it all onto ep80 back ends ok but fronts a bit different!
Much help as possible needed!
Thanks!!!
If i remember rightly the front slam panel bar bit (cant remember the name lol) is a different shape to the gt. I think me and short had this issue on his 85
The horizontal bar just under the headlights needs swapped, (bumper support bar) its more circular on the GT if you know what i mean, comes out further.
Yeah bumper bar is different between the two, and if you're fitting GT headlights (square or quad i think) you need to grind a bit out behind where the hedalight sits as the ep80 ones sit very shallow compared to the GT ones. I had to wire the headlights/main beam up using spade terminals (soldering would be better obviously but was quicker to just crimpt them at the time rush rush rush haha)
