N102nathan Posted September 10, 2014 Posted September 10, 2014 Hi all,I've had my car for all of a week it's had hybrid ct9 and air filter relocation fitted also a catch can. My problem is the pipe coming from the rocker breather on the left goes to the catch can which vents to air was kinked. The pcv valve breather is standard setup. I straightened this pipe out and it caused my car to start smoking. My mechanic said this mayst of caused a vacuum which slowed the pcv to draw oil into the inlet. We made a restrictor so it can still breath but not as much and it stopped the smoking. Is my pcv buggered or do I need to vent this into the can also???Any help apprieciated CheersNathan Quote
N102nathan Posted September 10, 2014 Author Posted September 10, 2014 Meant to say allowed the pcv not slowed Quote
turbo Grant Posted September 10, 2014 Posted September 10, 2014 It might be me but that sounds confusing. If you blocked off that pipe on the left it would cause the engine to badly. But with it open and no kinks with full flow it shouldn't smoke. Test the pcv by removing the pipe on the inlet if you can blow into the engine it's fucked Quote
mikey4410 Posted September 10, 2014 Posted September 10, 2014 You shouldn't have a pcv still on there mate.u need to vent bith to air with a elbow no longer than 2" Quote
N102nathan Posted September 10, 2014 Author Posted September 10, 2014 It wasn't completely blocked it was kinked but sAllowing a small amount of air through. Haven't blocked it completely back of made up a restrictor for it Quote
N102nathan Posted September 10, 2014 Author Posted September 10, 2014 It was smoking on idle on and off and as you pulled up to a stop at a junction etc if that helps. I initially thought turbo but we checked it and it's sound. Was concerned it might be my rings gone and once I allowed it to breath properly the oil vapor was being pushed out but there was nothing in the catch can from the breather on the left. Quote
