Stefan_s Posted September 12, 2014 Share Posted September 12, 2014 hi, i bought an avcr off ebay and all the wires have been chopped and its using a non apexi map sensor but have no idea what colour wires are for the map sensor on the actual avcr, would anyone with one that would be able to have a look for me and let me know thanks Quote Link to post Share on other sites
aaddzz123 Posted September 12, 2014 Share Posted September 12, 2014 I did a guide for this. GIve me a sec Quote Link to post Share on other sites
aaddzz123 Posted September 12, 2014 Share Posted September 12, 2014 http://www.ukstarletowners.com/topic/60485-a-guide-to-fitting-and-setting-up-the-apexi-avc-r/The solenoid uses a pink and red wire on one side and a pink and black on the other. The pink goes to the pink and the red goes to the black.The sensor wires are: Yellow - Red, Brown - Black and Blue white.All other wires are explained in the guide.Hope this helps mate Quote Link to post Share on other sites
Stefan_s Posted September 12, 2014 Author Share Posted September 12, 2014 thats perfect mate much appreciated, will give it a bash tomorrow, i got everything else wired up and after a drive the rpms are well out compared to my rev counter, could i have connected it to the wrong rpm connection on the ecu? Quote Link to post Share on other sites
aaddzz123 Posted September 12, 2014 Share Posted September 12, 2014 I had the same problem when I first installed it. It's because it will be set up as a 6 cylinder engine. You need to go into the settings and change it to a 4 cylinder. I think it's under "ETC" or something, I can't remember to be exact. Quote Link to post Share on other sites
Stefan_s Posted September 12, 2014 Author Share Posted September 12, 2014 ah that would make sense now as it was removed from a skyline Quote Link to post Share on other sites
