matthew ep91 Posted September 23, 2014 Posted September 23, 2014 my glanza hits solid somtimes wen goin from 2nd to 3rd ? any one no the problem Quote
akyakapotter Posted September 23, 2014 Posted September 23, 2014 What do you mean hits solid? What quick shifter do you have? Quote
matthew ep91 Posted September 23, 2014 Author Posted September 23, 2014 i dont have a quick shift i mean when i change gear quickly it just wont take 3rd most of the time ? i have a 6speed box from a g6 mate . do you know what the problem could be ? Quote
matthew ep91 Posted September 23, 2014 Author Posted September 23, 2014 it feels like its getting jammed Quote
akyakapotter Posted September 23, 2014 Posted September 23, 2014 Could be a number of things really I'd say synchro meshes are going. possibly old oil clutch going cables stretched the list is endless Quote
matthew ep91 Posted September 23, 2014 Author Posted September 23, 2014 what oil should i use ? and would i need cablss from a glanza or a corolla ? Quote
matthew ep91 Posted September 23, 2014 Author Posted September 23, 2014 if i was to change gear linkage bushes ? would i need them from a corolla or a glanza ? Quote
srferreras Posted November 19, 2014 Posted November 19, 2014 I have the same problem. could you fix it? Quote
Ryan_EP82 GT Posted November 19, 2014 Posted November 19, 2014 Bent selector rod maybe? Shifter bushes? Glanza bushes Matthew if your using your existing cables Quote
srferreras Posted November 20, 2014 Posted November 20, 2014 dear members, any modification to the transmission 2nd gear to fit fast at high rpm? Quote
5e colin Posted November 20, 2014 Posted November 20, 2014 try rotating the sugar cube on the selector arms !! Quote
