Adam M Posted September 28, 2014 Posted September 28, 2014 Hey allAs title saisWhenever i start to build boost engine managment light comes onGetting fault code 12have no idea why as the car runs absoloutly fineOnly thing i dont have attached to the car since doing engine swap is this bracket with a blue hose , cant see anywhere that it fits to the engine.Can anyone shed some light?Have new leads/dizzyStarter motor whines for a sec as i start carNo smokeBoost fineruns greatMany thanksAdam Quote
Stu Posted September 29, 2014 Posted September 29, 2014 Looks like the hard line from the turbo actuator up to the high/low boost solinoid - wont cause your issue How much boost are you running? 12 is usually a signal issue from the dizzy to ecu Quote
Adam M Posted September 29, 2014 Author Posted September 29, 2014 (edited) Ok stu that makes sense as high/low boost switch doesnt change pressure , i'll check all over dizzy thanks for the input budAnd i am running 12 psi atFull boostAdam Edited September 29, 2014 by Adam M Quote
Stu Posted September 30, 2014 Posted September 30, 2014 It could be right on the verge of boost cut as from memory its about 12psi for a EP91 ecu? Just seems weird its throwing that error code. Quote
Adam M Posted September 30, 2014 Author Posted September 30, 2014 Could be bud i'll try remove the fcd in the morning Quote
Adam M Posted October 1, 2014 Author Posted October 1, 2014 Still no luck , proving a tough one to figure out Quote
Stu Posted October 1, 2014 Posted October 1, 2014 Have you taken a look at the dizzy and wiring back to the ecu? The wiring is shielded from factory so it may be worth checking its all still intact? Don't suppose you have access to an oscilloscope? You could confirm the output signal from the 24tooth and syncs to make sure the waveforms are as even? Quote
Adam M Posted October 2, 2014 Author Posted October 2, 2014 I've had a good scan at the wiring seems ok but i will have a detailed look tommorow nearer toThe ecu mate and i don't unfortunatly , Getting near to going to a reputable starlet mechanic and having the engine overlooked as i'm pritty new to cars hehe I greatly appreciate the help tho stu! Quote
