Hi all, im in the process of finalising all the parts ill need to fit my tf035, and have a few problems. Im going to be using the original water feeds, ive heard somewhere you can run td series turbos without with no problems but i want to be thorough with this install, and id like to know whether it matters which port the water is fed into.
I also want to use the internal gate for now as im not really going to be running hectic boost, and was wondering if theres an actuator or bracket that suits a forester tf rotated to suit a starlet, long shot i know lol but i thought id ask.
Finally, i was wondering what the actuator is made of, ill probably end up having to cut and weld it to suit a custom bracket and need to know what it is to weld it back together properly.
Cheers for any advice in advance!
Thats the chunkiest bracket of all time lol. Another thing that i was wondering come to think of it, liamd rotated my intake to face downwards when fitted, where does the piping from that setup go to get to the intercooler lol. I was gonna chop the flange off the ct9s first intercooler pipe and rotate the turbo to mach the old ct9s position. This would put the bolt holes for the actuator on completely the wrong side of the turbo annoyingly, i need to make a bracket to do that. Also, ive suddenly remembered some td04 setups arnt stock rad friendly, i have no idea if my kit will fit lol.
