Glanzacoley Posted October 3, 2014 Posted October 3, 2014 Can anyone tell me which pipe I have to run the boost line too? I have a greedy dump valve do I put the boost line to the pipe on the top of that? It then feeds back to the inlet manifold? Quote
JamesD89 Posted October 3, 2014 Posted October 3, 2014 yes use a t piece from the vacuum line to the blow off valve. Quote
Jay2ohh Posted October 20, 2014 Posted October 20, 2014 There's 3 vacuums coming off the inlet and iirc doesn't matter which one you cut, make a cut and put the tpiece there, boost gauge hose goes on the t and the hose you cut runs straight either side as normal, boost gauge hose, one end goes to the gauge and one end goes to the dump valve Quote
