5e colin Posted October 7, 2014 Posted October 7, 2014 first the piston sizes whit the head off and the timing belt on the left. at 12oclock on each cylinder theres a number stamped in the dec thats your piston size exactly where the yellow dot is ontop of each cylinder now turn over the engine and u will see this (pic) u will see the nrs on the crank they go from 0 to 2 and 5 nrs in total now on the block there are 5 more nrs (arrow) going from 1 to 3 example crank nrs 01121 block nrs 23123 actual bearing size 24244 these are the real bearing seizes u end up whit ( note the above markings ar not on the 4efte !!!!!! ) Cylinder Head: Warpage limit (block side) 0.05mm Warpage limit (Manifold side) 0.05mm Intake manifold: Warpage limit 0.1mm Exhaust manifold: Warpage limit 0.2mm Cylinder block: Surface warpage limit 0.05mm Bore diameters: STD mark 1 = 74.000-74.010mm STD mark 2 = 74.010mm-74.020mm STD mark 3 = 74.020mm-74.030mm Limit before rebore = 74.23mm Piston diameter: STD mark 1 = 73.900-73.910mm STD mark 2 = 73.910mm-73.020mm STD mark 3 = 73.920mm-73.930mm Piston to oil clearance: STD = 0.09-0.11mm Limit = 0.13mm Piston ring groove clearance: Top ring = 0.04-0.08mm 2nd ring = 0.03-0.07mm Piston ring end gap: Top ring (STD) = 0.26-0.36mm Top ring (Limit) = 0.95mm 2nd ring (STD) = 0.15-0.30mm 2nd ring (Limit) = 0.90mm Oil control ring (STD) = 0.13-0.38mm Oil control ring (Limit) = 0.98mm Con-rods: Thrust clearance (STD) = 0.15-0.35mm Thrust clearance (Limit) = 0.45mm Big-end inner diameter: STD mark 1 = 43.000-43.007mm STD mark 2 = 43.007-43.014mm STD mark 3 = 43.014-43.021mm U/S 0.25 = 43.000-43.021mm Rod bearing centre wall thickness: STD mark 1 = 1.487-1.491mm STD mark 2 = 1.491-1.495mm STD mark 3 = 1.495-1.499mm U/S 0.25 = 1.607-1.613mm Con-rod oil clearance: STD = 0.016-0.048mm Limit = 0.08mm Maximum allowable bend in rod per 100mm = 0.03mm Maximum allowable twist in rod per 100mm = 0.05mm Crankshaft thrust clearance: STD = 0.02-0.20mm Limit = 0.30mm Main journal oil clearance: STD = 0.016-0.049mm U/S 0.25 = 0.017-0.061mm Limit = 0.08mm Main journal diameter: STD mark 0 = 46.995-47.000mm STD mark 1 = 46.990-46.995mm STD mark 2 = 46.985-46.990mm Main bearing centre wall thickness: STD mark 1 = 1.995-1.999mm STD mark 2 = 1.999-2.003mm STD mark 3 = 2.003-2.007mm STD mark 4 = 2.007-2.011mm STD mark 5 = 2.011-2.015mm U/S 0.25 = 2.115-2.123mm Crank pin diameter: STD = 39.985-40.000mm U/S 0.25 = 39.745-39.755mm Limit = 0.06mm Circle runout (Limit) = 0.06mm Main journal taper and out-of-round (Limit) = 0.02mm Crank pin taper and out-of-round (Limit) = 0.02mm Torque settings: Cylinder head bolt: First 36ftlb Second - turn 90 degrees in same sequence Cylinder head to camshaft bearing cap: 9ftlb Cylinder head to intake manifold: 14ftlb Cylinder head to exhaust manifold: 35ftlb Cylinder head to water outlet housing: 13ftlb Cylinder head to Cylinder head cover: 61inlb ** note inch pounds, not foot pounds! ** Camshaft to Camshaft timing pulley: 37ftlb Cylinder block to crankshaft bearing cap: 42ftlb Cylinder block to rear main oil seal retainer: 65inlb ** again note inch pounds ** Cylinder block to oil filter union: 18ftlb Crankshaft to flywheel: 65ftlb Con-rod cap to con-rod: 29ftlb (18ftlb then +90 degrees) Oil pump pulley to drive rotor: 27ftlb Quote
